viclykewhoa Posted November 22, 2005 Share Posted November 22, 2005 Does anyone know how to take off the driver and passenger seat backs in a '99 GS300 so that the power seat motors/hinges/et al can be greased? My seats are not reclining/inclining as smoothly as they used to. It also sounds like they could need some grease. Let me know. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted November 23, 2005 Share Posted November 23, 2005 Does anyone know how to take off the driver and passenger seat backs in a '99 GS300 so that the power seat motors/hinges/et al can be greased? My seats are not reclining/inclining as smoothly as they used to. It also sounds like they could need some grease. Let me know. ← Remove the 4 bolts holding the seat down, carefully remove it, it's heavy. Set it on the ground on a blanket, flip it over and lube it up with a high quality synthetic grease. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted November 24, 2005 Share Posted November 24, 2005 To just remove the back, slide the seat to a position where the lower part of the back panel clears the seat tracks. Lift the seat to the up-most position. If memory serves me, there are two screws through the bottom of the seat back straight up. They are possibly recessed and hard to see. You'll probably need a stubby #2 phillips screwdriver to access them. The upper part of the seat back is held on by clips. Quote Link to comment Share on other sites More sharing options...
