lotrel95 Posted October 30, 2005 Share Posted October 30, 2005 the problems I'm having with me car is the srs light and the dash board clock stays on even if the car is turned off. If I don't start my car at least twice aweek my battery will die....I replaced the battery, and even did the good old (ALT.) test, by starting the car and then disconnecting the positve cable and the car stayed running. The only problem I did see is when the car is off, if I take the cable off, and then put it back on I get a pretty good spark & sizzel from the battery post...what could this be???? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted October 30, 2005 Share Posted October 30, 2005 Read the first note here. A voltage drop to the SRS module will cause the light to remain lit. Checking procedures are detailed below. SRS_Remains_Lit.pdf SRS_Display_Codes.pdf SRS_Codes.pdf SRS_Clearing_Codes.pdf SRS_Center_Module_Locatation.pdf Quote Link to comment Share on other sites More sharing options...
