dabattis Posted October 28, 2005 Posted October 28, 2005 I have a 1997 ES300. The Radio LED screen that shows the channel has burnt out. I was wondering if anyone has had the same problem and knows how to replace it.
mburnickas Posted October 28, 2005 Posted October 28, 2005 I have a 1997 ES300. The Radio LED screen that shows the channel has burnt out. I was wondering if anyone has had the same problem and knows how to replace it. ← This has come up before, so do a search. I say that since there are LOTS of posts on it. Here is one: http://us.lexusownersclub.com/forums/index...showtopic=12761 I just bought a new LCD myself. $95 and I will replace mine this weekend. Mine went nuts so I pushed on the LCD screen. It helped and went back to normal but I guess it does not last long. So I bought the new screen and will be installed in tomorrow. PS. Welcome to LOC!!!! :D :D :D :D
dabattis Posted October 28, 2005 Author Posted October 28, 2005 Thanks, will do. Let me know if you have any helpful hints after you replace yours.
mburnickas Posted October 28, 2005 Posted October 28, 2005 Thanks, will do. Let me know if you have any helpful hints after you replace yours. ← I will. loosks pretty easy
dabattis Posted October 28, 2005 Author Posted October 28, 2005 Thanks, just wanted to let you know I'm originally from Worcester. I was relocated to Phoenix last year. With what you sent me it looks like there is quite a few of us with this problem.
mburnickas Posted October 29, 2005 Posted October 29, 2005 Thanks, just wanted to let you know I'm originally from Worcester. I was relocated to Phoenix last year. With what you sent me it looks like there is quite a few of us with this problem. ← lots of people I think
mburnickas Posted October 29, 2005 Posted October 29, 2005 Thanks, will do. Let me know if you have any helpful hints after you replace yours. ← Done. Pretty easy! Some things to remember or FYI 1) The radio removal PDF is pretty good! Follow it. For me the bottom plastic part was more of a pain then the top AC. The top part just "prys" out while the bottom has to stop long clips on the side. 2) Be sure to put shirts or anything over plastic since it does scratch. I used shirts by shifter and the blue painters paint tape of all other parts. I DID scratch some since I think you can't avoid it. The radion and metal frame is a tight fit. 3) I removed the radio in 25 minutes. When taking off radio plate face plate be careful. There are plastic slips on 3 of the 4 sides. 4) Putting the new LCD in is easy. The wire harness can be a little pain just pull easy. 5) AFTER installing new LCD make sure the screen is clean. I had little white plastic flakes on mine AFTER I installed the radio in the car (SUCKED) . So I had to remove it again since the dirty LCD was driving me crazy. So removed again and cleaned. :D 6) it is easy total time was 54 minues for 2 removals. First one was 37 minutes. It is very easy. Any questions ask!
donrobbery Posted May 8, 2006 Posted May 8, 2006 is it the same for a gs300 mine doesnt work on the passenger side
Dardan Posted January 3, 2007 Posted January 3, 2007 is it the same for a GS300? mine doesnt work on the passenger side Pretty much, yes. You can look here for more information.
