hogair Posted October 28, 2005 Share Posted October 28, 2005 My 98 GS 300 makes morse code sounds. It is coming from the abs brake pump. I can feel it with my hand when stopped and my hand on pump. It just does it sometimes. When it stops either it is fine or the BRAKE, VCS, VCS OFF Lights come on. A mech. told me those pumps never go bad! [pump cost $1650 at Lexus] he said maybe to much brake fluid. It was a little low so I added some- same problem. Sounds like the pump may be cavitating. Can you bleed them? Any suggestions? Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted October 28, 2005 Share Posted October 28, 2005 If you had searched you would know that they do fail and it's quite costly <_< I'm sure it can be bled, however that's probably not your problem. Quote Link to comment Share on other sites More sharing options...
hogair Posted October 29, 2005 Author Share Posted October 29, 2005 If you had searched you would know that they do fail and it's quite costly <_< I'm sure it can be bled, however that's probably not your problem. Hello again, I searched-about 3.5 hours, read it all. Did not find an answer. That is why this post is up- To get some suggestions on what to do or wher I can buy some parts other than the Lexus dealer. Quote Link to comment Share on other sites More sharing options...
