TexasRX300 Posted September 11, 2005 Posted September 11, 2005 Check engine light coming on. Garage diagnosed that it needs O2 Sensor Bank 1 Sensor 1. Where is best place to buy online and is this the front or rear sensor? Thanks in advance
ravenracer Posted September 11, 2005 Posted September 11, 2005 Check engine light coming on. Garage diagnosed that it needs O2 Sensor Bank 1 Sensor 1.Where is best place to buy online and is this the front or rear sensor? Thanks in advance ← Hey wasup i know site Oxygen sensor i dont know if its the front or back see this post might help you Sensor location ect
TexasRX300 Posted September 11, 2005 Author Posted September 11, 2005 Thanks for the links, I should have said...The Cheapeast place on the internet to buy them.
mikey00 Posted September 12, 2005 Posted September 12, 2005 Given the problems that some have had with using aftermarket sensors, I would stick with OEM. There's nothing worse than troubleshooting a code when the new sensor itself is causing a code. This has caused some DIY ers to spend quite a bit of money on a simple fix. Try newlexusparts.com and irontoad.com. Irontoad doesn't have them listed on the site but a phone call should do it.
