When I bought the car it did not run. The motor was seized due to oil starvation After installing a Japanese engine in my 1992 lexus es300, and running the engine, raw fuel comes from the tailpipe. I then removed the motor and exchanged it for another motor which I installed in the car only to do the same thing. I do not know where to start. The engine in the car now is a japanese engine with a US intake manifold it runs but is missing and has fuel coming from the tailpipe. any help is appreciated.
Sounds like you've got weak ignition in some cylinders. A 3vz-fe will run on 2 of 6. Stupid !Removed! OBD-I won't even throw a code. :\
Check the coil, dsitributor's rotor & cap, plugs & wires.
On a side note:
What's:
The cam timing
Ignition timing
"VS" voltage comming from the air-flow meter (Yellow wire-blue stripe, or cut the top off & check the votlage on the flap arm) with the engine off & the key ON, & with the engine idling
what is the voltage on VF1 & VF2 with the engine idling
Fuel pressure @ idle
Unplug the cold-start injector's electrical connector & see if it goes away
Check injector duration (Digital multimeter's dwell function)
How bad is the gas smell / fuel vapor. If the cat is bad, or you don't have one, it's going to be like that until the o2 sensors warm up & the engine enters closed loop mode.
