Does anyone know how to get the BB 7100t to work with the LS430? Is there a patch you can load to the phone somewhere? Such a great car and a great phone, surely the two must be able to work together?
Thanks,
  • 3 weeks later...
I have an 05 RX400H and my BB 7100G works perfectly with the Bluetooth - I use it almost everyday during my commute.
  • 4 weeks later...
What passcode did you use to get it working. I have a 7100g with a LS430 05. Is there a specific version of bluetooth you need?
Help!
Help!
I got it working after 3 days of trying.
Some notes:
I needed to delete all of the phones installed
Remove all phone types
Reset or turn car off and on to reset Unit
Enable Bluetooth on BB
Set type to Bluetooth Handsfree (on car)
Set type to Bluetooth Handsfree (on BB 7100)
Set BB to Discoverable
Select Trusted to yes under device properties
Select "find devices" on BB - I tried this at least 10 times
Select "Setting" on car - will start device search (1 minute time out)
Hold BB near the GPS unit display - don't ask me why...
Should be prompted to enter passcode (0000)
Select "Add Phones" (on car) - should display BB device
Select BB device
Once all of the setting have been set then you need to "OK" everything and restart the unit or car.
I was not taking notes during this process. I was actually getting ready to return the BB because I could not get it to work. I cannot promise this will work but it might be a good start.
Good luck.
I have not tried to sync the contacts list or calendar.
