rvsvlexus Posted August 8, 2005 Share Posted August 8, 2005 I own a 2005 RX330. I understand that within the first year the dealer will change factory default settings free of cost if requested. My question is have you got any defaults changed? If so could you list them? As of now, I have this one in mind for my RX: * Unlock all doors by pressing the remote key only ONCE. Currently (default setting) I have to press it twice rapidly to unlock the doors Quote Link to comment Share on other sites More sharing options...
vinnyraj Posted August 9, 2005 Share Posted August 9, 2005 I own a 2005 RX330. I understand that within the first year the dealer will change factory default settings free of cost if requested.My question is have you got any defaults changed? If so could you list them? As of now, I have this one in mind for my RX: * Unlock all doors by pressing the remote key only ONCE. Currently (default setting) I have to press it twice rapidly to unlock the doors ← I just had my settings changed on my 05 RX330. I did the same as you wanted so that ll four doors unlock by pressing the remote key once. Others include: While holding the remote key down, all windows/moonroof open. You can change this so that ur moonroof tilts, rather than sliding open. When you put ur car into park, all doors unlock (this can be changed) You can have the option so that you can open the rear door without having to unlock all of the doors first. You can change the sequence so that you do not have to hold down the remote key for .8 seconds in order to open rear door (Instead, you can press it twice). You can change the option of having the signal lights blink when you lock the doors (I think you can make the car honk once when you lock the doors) The dealer has a form you can highlight which settings you want applied to your RX330. Hope this helps Quote Link to comment Share on other sites More sharing options...
