A/c Drain Tube
Open your sunroof. At both front corners of the bodywork, there will be a small hole to let water drain.
What normally happens, is that line backs up on the driver's side (go figure). The water can't drain so it'll spill over the "tray" out into the back, either directly there, through the liner, or on the seat & down.
They're hard to see, run your finger through the joint in the bends. You'll feel them.
I could be wrong here, but water in the rear assenger footwell is usually an indicator of a clogged A/C drain on the ES.
Drive around for a while w/ the A/C on. Then park and come back to the car after a few minutes to see it there is water pooled on the gound. If not then there's a telltale sign it's the A/C.
I know it's clogged. Where are the drains ?
Thank you for the response, but maybe a lack common sense, how does the sunroof drain affect the a/c drain?
The drain is the only rubber drain hose under the front of the cabin. Runs right by the exhaust, make sure it's not plugged.
Blow compressed air through the sunroof drain holes.
Same thing for the passanger side!
