danwhip Posted August 5, 2005 Posted August 5, 2005 Where is the A/C drain tube located ? Can anyone help ?
bigferg Posted August 5, 2005 Posted August 5, 2005 Where is the A/C drain tube located ? Can anyone help ? ← check roof drains had same problem went to lexus dealer he said drain came loose hope this helps you
Toysrme Posted August 6, 2005 Posted August 6, 2005 Shoot 20psi in the two front drain holes. Then shoot 80-90psi through them. 99% of the time, you'll fix it.
danwhip Posted August 10, 2005 Author Posted August 10, 2005 Shoot 20psi in the two front drain holes. Then shoot 80-90psi through them. 99% of the time, you'll fix it. ← Where are the two front drain holes
Toysrme Posted August 12, 2005 Posted August 12, 2005 Open your sunroof. At both front corners of the bodywork, there will be a small hole to let water drain. What normally happens, is that line backs up on the driver's side (go figure). The water can't drain so it'll spill over the "tray" out into the back, either directly there, through the liner, or on the seat & down. They're hard to see, run your finger through the joint in the bends. You'll feel them.
branshew Posted August 13, 2005 Posted August 13, 2005 I could be wrong here, but water in the rear assenger footwell is usually an indicator of a clogged A/C drain on the ES. Drive around for a while w/ the A/C on. Then park and come back to the car after a few minutes to see it there is water pooled on the gound. If not then there's a telltale sign it's the A/C.
danwhip Posted August 13, 2005 Author Posted August 13, 2005 I could be wrong here, but water in the rear assenger footwell is usually an indicator of a clogged A/C drain on the ES. Drive around for a while w/ the A/C on. Then park and come back to the car after a few minutes to see it there is water pooled on the gound. If not then there's a telltale sign it's the A/C. ← I know it's clogged. Where are the drains ?
Toysrme Posted August 13, 2005 Posted August 13, 2005 The drain is the only rubber drain hose under the front of the cabin. Runs right by the exhaust, make sure it's not plugged. Blow compressed air through the sunroof drain holes. Same thing for the passanger side!
danwhip Posted August 17, 2005 Author Posted August 17, 2005 Thank you for the response, but maybe a lack common sense, how does the sunroof drain affect the a/c drain? The drain is the only rubber drain hose under the front of the cabin. Runs right by the exhaust, make sure it's not plugged.Blow compressed air through the sunroof drain holes. Same thing for the passanger side! ←
Toysrme Posted August 18, 2005 Posted August 18, 2005 A lot of times they get mistaken for each other. If noting else, maint. ;)
