air12290 Posted August 1, 2005 Share Posted August 1, 2005 1 was told my 90 LS400 needed a new ignition control module.. which, easily enough is attached and accessible. I took off the two connectors, and took of the 2 screws to the old one. Unfortunately, when I went to put on the new one, I had purchased the wrong one, and the plug in did not quite fit.. so I cleaned up the old one and went to reattach.. however, when I went to put the two plug on connectors back on, I wasn't very careful on the second one.. and bent one of the 6 pins.. so even when I get the correct ICM, that connector won't work. Question is, the connectors that plug ON to the ICM.. where do those wires go to? I think I can buy a connector with the wire, but not sure what it leads to thanks Quote Link to comment Share on other sites More sharing options...
vyhanh Posted August 1, 2005 Share Posted August 1, 2005 Hi, I think that if you can get a wiring diagram, it will show all the wiring, their colors, and where they are connected. Quote Link to comment Share on other sites More sharing options...
