Does anybody know what's up with these two things?
My cigarette lighter doesn't work for some reason, it's not the fuse. The dealer said they would have to investigate further and I said forget about it.
Every now and then when my car has been sitting for awhile and I start it it will rev. around 1800rpm and stay there. If I try to rev the engine it will almost stall and it is basically not drivable w/ the engine like this. If I start and stop the engine a few times it will clear itself up and off I go.
Thnx!
the lighter, well trace the wires and see if they are disconnected somewhere.
As for the other, The dealer can put the car on to their trouble code computer and find the problem alot easier then you can sound out what it doesn't do to anyone here on these boards ;)
Did you try replacing the lighter itself (you know the puch in part) Mine didn't work either when I bought it, so I went to Pep Boys and bought an aftermarket one for a few bucks and presto it works. I would hope that Lexus would have tried this though.
