bmkrantz Posted July 25, 2005 Share Posted July 25, 2005 I drive a 2001 ES300, currently with 72,500 miles. How often should i change oil? I have been doing it close to every 3 months, which has averaged about 4,000 mile intervals. Do I need to do all these (costly) big maintenance efforts, for examples at 60,000 miles? When do i need to change the timing belt? Quote Link to comment Share on other sites More sharing options...
melhadri Posted July 25, 2005 Share Posted July 25, 2005 3-4k mile oil change intervals is just fine especially if most of the milage is highway? I personally would invest in the 60k mile service. Timing belt replacement is recommended at 90k miles. Take a look at this link for service details: http://www.edmunds.com/maintenance/Mainten...ng.secnav.8.1.* Quote Link to comment Share on other sites More sharing options...
mburnickas Posted July 25, 2005 Share Posted July 25, 2005 I drive a 2001 ES300, currently with 72,500 miles.How often should i change oil? I have been doing it close to every 3 months, which has averaged about 4,000 mile intervals. Do I need to do all these (costly) big maintenance efforts, for examples at 60,000 miles? When do i need to change the timing belt? ← I would use the search function on the forum since there is LOTS of good info. Your oil drain interval is integral to the oil you use. You can go from 3,000 miles drain to up to 20K if you wanted. I do about 4 to 4.3X longer then you do. Most times the 45, 60, 30 etc are a ripoff if you know some basic car stuff. Having to paying Lexus to rotate your tires, or put blades on wipers, or check this and that is nuts. The major ones are the timing belt, water pump, tranny, pulleys, tensioner, thermostat, seals, plugs etc. Yes 90K is it since you have an VVTi engine which menas if the belts break, you have MAJOR issues. Quote Link to comment Share on other sites More sharing options...
