Check Light Comes On Sometimes
rajinder
Checklight comes on will after runing the car for 10 minutes .
I have workshop in mumbai .
I have scanned the car with Launch scanner and we are getting fault code (4 nos)
P0171 ,P0174 , P1656 , P 1663. .
Can i get solution to my problem.
Thanks.
Rajinder.
Thanks.
Rajinder.
This is the vehicle detailing section. . .
When this happened on my Lexus I opened the gas cap and then closed it again problem resolved. . .
Rajinder
According tomy diagnostics software the codes have the following meanings
P0171 System too lean bank1
P0174 System too lean bank2
P1656 OCV circuit malfunction bank 1
P1663 OCV circuit malfunction bank 2
Looks like the fuel air mixture has too much air as a result of a problem with the OCV. Sorry, I don't know what an OCV is. I assume it is an air intake regulating valve. Youll need to find out what that is then check the wiring. If that's all ok, then I guess itwill be the OCV itself
Hope this helps
Mike
