cdm Posted July 6, 2003 Share Posted July 6, 2003 Allright I've seen some of these being discussed but there is always something left out. Correct me/fill the blanks if you can. So here goes: Gauge Cluster: - Needles: 9leds per needle, non repairable. Can it be replaced or does it require an entire cluster? Will lexus order only the needles? - backlight bulbs. Repleacable? Whats the chance of the actual fuse/contact being damaged so changing the bulb makes no difference, like is it possible? - Warning indicators: bulbs and they are replaceable right? - Gear indicators: bulbs and they are replaceable right? Is the backlight color bulb dependant or is it in the gauge face transparency itself? Center Console: - Climate control: bulbs, leds, combination of both? Which can be changed or is a new unit neccessary. - Stereo: same as climate control? Sunroof: - i don't suppose the controls are lit up? I am asking for the '93-97 models (mk1) as I am about to buy one and the lights issues are something that *will* happen. If not already present at purchase. Cheers guys B) Quote Link to comment Share on other sites More sharing options...
