Stero Question For 98 Gs300
Ok.. first off I did a search, and there is a similiar topic right bove this one that doesn't answer my question.
I have a 98 GS300 and I am going to install an aftermarket cdplayer/navigation into it.
I am an installation shop manager and I have been installing for 10 years but I was looking for some easy answers instead of a long drawn out process of testing.
The harness on the back of the radio is a standard 1761 (if you are familiar with metra part #'s) harness. The same one found on all toyotas since the dawn of the 80's. However, the wires are not in the "normal" locations.
I need a link to the wiring colors or a list of them if possible. I have found power with no problems but I need to find the amp turn on and the speakers signal wires. Also, if I need any special type of adaptor that would be handy info as well.
My shop has a book that lists a 70-8112 harness (which is the RCA input harness used on amplified Avalons, etc..) this is not the correct harness.
Any help is greatly appreciated,
-Sean
Saw that post and skipped over it because it showed a link to the wrong harness. Then it stated that he didn't have the info on the factory remote turn on. However I did miss the pdf file somehow.
I did come across numerous posts by you, which all seemed to include this wonderful smiley: <_< and alot of "blah blah blah, search newb" type of posts. Instead of being a toolbox, you could have just kept your trap shut or posted the link, which I would think should be a sticky over in the audio forum at the very least.
So, EFF you very much for the "help"
The reason there was no mention of a remote turn on in the post you were sent to by our esteemed member TurboGS300 is simple. There is none. The amp is triggered over the data bus with a serial data stream.
