tmphan Posted June 21, 2005 Share Posted June 21, 2005 does anyone know where i can get the wiring harness or harnesses to install an aftermarket head unit it is a sony.....i already have the dash kit.....i just need something to connect the sony to the car another question.....is there any way to still use the cd changer after i install the sony? Quote Link to comment Share on other sites More sharing options...
PIONEERSUBY Posted June 29, 2005 Share Posted June 29, 2005 does anyone know where i can get the wiring harness or harnesses to install an aftermarket head unit it is a sony.....i already have the dash kit.....i just need something to connect the sony to the caranother question.....is there any way to still use the cd changer after i install the sony? ← you cant use the factory amp so the harness has to reach under the seat to connect to to output speaker wires. and no you cant use the factory changer with the 199.00 sony cd player. better to fix the $4,000.00 factory system with the 199.,00 then go aftermarket. Quote Link to comment Share on other sites More sharing options...
