jimmouse Posted June 16, 2005 Posted June 16, 2005 P1130 Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1) Just drove thru a bump during a wet day. Then engine light anb VSC light turned on. This happened every 4-5K miles since last October. I usually disconnect the battery and the light will remain off for another 4-5k miles. Any one here has same experience? Any cause or solution? Thanks a lot.
steviej Posted June 19, 2005 Posted June 19, 2005 the A/F sensor is getting lazy if not ready to die. Ultimate fix is to replace it. This sensor is the hardest to get at. It is between the cat and the cylinder block on the bank of cylinders closest to the firewall. Not much wiggle room back there. Sensor will run you about $225 from Toyota, $275 from Lexus, but you may be able to get a Denso sensor on line (www.sparkplugs.com). steviej
jimmouse Posted June 21, 2005 Author Posted June 21, 2005 the A/F sensor is getting lazy if not ready to die.Ultimate fix is to replace it. This sensor is the hardest to get at. It is between the cat and the cylinder block on the bank of cylinders closest to the firewall. Not much wiggle room back there. Sensor will run you about $225 from Toyota, $275 from Lexus, but you may be able to get a Denso sensor on line (www.sparkplugs.com). steviej ← STEVIEJ. Thanks a lot. Next time it come up, it will be in the garage.
