The 18" tire size recommended for your 2000 RX is 255 55 18 so I don't know for sure if you can use the OE set up. I'd leave the factory size you have on now personally. Just my 2 cents. B)
:cheers:
i've been digging... rx330 18" oem fitment was 235/55r18 ? why is it narrower? what kind of acceleration/odometer issues will i run into? :blink:
That set up is for the RX330, not the RX 300.....totally different vehicles & generations of RX were talking about here. In the 255 55 18 size, any odo & speedo changes should be kept to a minimum. ;) Have a look for yourself as to what is recommeded. B)
http://www.tirerack.com/tires/OptionalTire...00&autoModClar=
:cheers:
