Strange Noise From Behind Nav
i have a 2001 gs300 with nav and i noticed that when i turn the key to the on position or start the car, there is a strange "puttering" noise comming from behind the nav system. I opend the glove compartment and i can clearly hear the noise comming from behind the nav system. its not the cd changer, i am thinkg it has someting to do with the hvac control, does anyone have any idea or similar experience. thanks a bunch for any advice.
Bill
i think i found an answer to my problem, here it is:
Swishing Water Noise???
I am having a strange problem, which is occuring after I went to my
30,000 mile service at the Lexus dealer:
When I drive off, you can hear some kind of "swishing" water sound from
behind the dash, as if water or SOME liquid is transferring itself to a
different location. And it's kind of loud too, so noticeable because
the Lex is such a quiet car.
I'm about to take it back to the dealer, but I was wondering if any of
you have had a similar strange problem such as this. Actually, I
faintly remember reading a thread awhile back about some issue similar to
this one, but I couldn't find it.
I really don't want Lexus to tear apart my car to find it either. If
they can't pinpoint it quite easily, I'm going to grow worried that
they'll want to do some major prying behind the dash or in the engine bay,
on a search mission.
I only hear it when I am pulling off, and sometimes when I am coming to
a stop. It almost sounds like a screw is loose and run amok, but it
sounds more like liquid or even sand/dirt that is changing positions
everytime I pull off.
Hmmmmmmmmmmmmm........
KevinGS
View Public Profile
Send a private message to KevinGS
Find More Posts by KevinGS
Add KevinGS to Your Buddy List
04-16-05, 08:58 AM #2
T.L.W.
Ancient Thread Bumper
lol this happened to me too
let me find the thread
here ya go
i hope it the same thing
http://www.clublexus.com/forums/sho...highlight=water
__________________
the will to WIN
T.L.W.
View Public Profile
Send a private message to T.L.W.
Find More Posts by T.L.W.
Add T.L.W. to Your Buddy List
04-16-05, 09:14 AM #3
KevinGS
Pole Position
Thanks a ton, TLW, for finding your thread.
So let me get this straight:
You did exactly as Sal said in your thread...taking off radiator cap,
capped off the coolant, started the engine (with radiator cap off), let
car heat up 'til cooling fan kicked in, turned the heat up, let the fan
cycle one more time (with no coolant added), tightened the cap (with
car still running)...and whalaaaaaaaaahhh! It was fixed?!? WOW!
Or do you think it's just best to have the system completely flushed
out and drained?
KevinGS
View Public Profile
04-16-05, 01:16 PM #4
BkLexZ
Pole Position
I tried that before and no luck. Still hear that damn water behind the
dash.
__________________
99 GS 300 Silver/Black
TTE Rear Spoiler
17" Chrome GS rims
BkLexZ
View Public Profile
Send a private message to BkLexZ
Find More Posts by BkLexZ
Add BkLexZ to Your Buddy List
04-16-05, 01:38 PM #5
T.L.W.
i drained everything out
but's thats only becuase i was working on the engine
__________________
the will to WIN
T.L.W.
View Public Profile
04-16-05, 08:05 PM #6
TAMR_GUS98
Pole Position
Posts: 343 Air Bubble.
When the dealer did your 30k, they drained the coolant like they were
supposed to but did not fill the coolant properly trapping air in your
heater core. Take it back to them and explain that this noise started
after the 30k service. They should know exactly what to do because it is
a well known problem.
Good Luck,
Will
__________________
"PRAISE THE LOWERED"
TAMR_GUS98
View Public Profile
Send a private message to TAMR_GUS98
Find More Posts by TAMR_GUS98
Add TAMR_GUS98 to Your Buddy List
04-17-05, 09:28 AM #7
salimshah
Lead Lap
Quote:
dash.
Out of curiosity, did you turn-up the heat (cabin temp HOT), else the
coolant inside the core, remains trapped along with the the air bubbles.
By the way, there can be other sources of water noise.
Salim
salimshah
View Public Profile
Send a private message to salimshah
Find More Posts by salimshah
Add salimshah to Your Buddy List
04-17-05, 10:03 AM #8
KevinGS
Pole Position
Thanks, TLW and Sal. I believe it has worked. But I will let you know
later this week when I drive the car more. I heard it ever so slightly
one time afterwards, but not the full "rushing water sound" since I did
Sal's procedure.
It took a while for that damn fan to kick in though, like 25 mins. And
then it took another 20 mins for it to cycle again with the heat on.
But it was worth it.
Question: Once the fan cycles and you turn the heat on, do you use the
Auto mode which turns the A/C on, or are you supposed to turn the heat
on without the A/C condensor on? Just curious. I turned it on using
Auto which kicked the condensor on as well of course.
Eventually, 15 minutes in, I turned the A/C condensor off, and left
only the heat on.
I still think it worked but want to know the correct procedure for
future reference.
Again, thanks a TON!
KevinGS
View Public Profile
04-17-05, 10:09 AM #9
SOFIA
Driver
i have the same problem!! they fix it and it comes back after 1month!
__________________
SOFIA
View Public Profile
Send a private message to SOFIA
Find More Posts by SOFIA
Add SOFIA to Your Buddy List
04-17-05, 07:07 PM #10
salimshah
Lead Lap
Boring details ...
Yes you have been warned
Complete water circuit has two choke points, thermostat and heat
exchanger (hot air supply to the cab). The key is to make them fully open.
Heat exchanger is controlled by cabin temprature set point. The cooling
fan only comes on after the thermostat is open, that is why the we wait
for the fan to kick-on. There are other indicators as well (if you can
safely look inside the radiator, you will notice a sudden surge in
water circulation, indicating the thermostat is open). So why do it twice?
Just for reassurance.
Auto climate control contributes nothing as the a/c compressor clicking
on would be at lower cabin temprature. Unless defrost is slected which
should increase engine load and may be contribute more to the heating
of the coolant.
In any case, it takes a while to heat up the coolant when the cabin
heater is on (which cools the coolant). That is why they say that if the
engine over-heats, turn on the cabin heater.
Word of Advice: If your overflow reservoir does not have coolant above
"min" there is a chance that your coolant circuit will suck in AIR. You
will be plagued by the bubble trouble.
Salim.
salimshah
View Public Profile
04-17-05, 08:32 PM #11
KevinGS
Pole Position
Quote:
Originally Posted by salimshah
Boring details ...
of the coolant.
Salim.
Thank you, THANK you, THANK YOU... for all those boring details. I
think I understand now.
And I never have checked my reservoir, so it may be low. When adding
coolant, can you add regular green-ish anti-freeze, or do you have to add
some special Lexus-brand (reddish?) anti-freeze?
Sal, thanks for all the info. Those details have brought me full
circle.
KevinGS
View Public Profile
04-17-05, 08:44 PM #12
corkycal
Lead Lap
you should be using the same anti-freeze for the whole system, toyota
long life or extra long life.
don't mix your anti-freeze with the green stuff unless that is what you
used in the first place.
corkycal
View Public Profile
Send a private message to corkycal
Find More Posts by corkycal
Add corkycal to Your Buddy List
04-18-05, 07:39 AM #13
corkycal
Lead Lap
i have a question,
Does our GS have an air bleeder valve to take out air from the system?
Or, to take air out of our system, do as Salim described?
corkycal
View Public Profile
04-18-05, 07:44 AM #14
chuckb
Lexus Champion
yes, I think it's near T stat.........
__________________
  • 3 months later...
Did you ever get a fix for the clicking behind the Nav?  I just got a 01 GS300 with the same problem and need some help.  Thanks!
no, but when i turn the heat up to over 80, it goes away, then i turn the heat back down to 66. the noise goes away until i turn the car off, then the next morning its back, so i turn the heat back up to 80 and so goes the story, i guess i need to take it to the dealer....
