unixgrl Posted June 7, 2005 Share Posted June 7, 2005 I had the factory head unit removed from my 2001 GS300 and replaced it with a Pioneer AVIC-N2. I'd like to hook the head unit up to the factory subwoofer amp. Is this possible? I don't know if the factory amp has RCA's or if there is something I can buy to convert the preouts to something the amp can use. Thanks for any help Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted June 8, 2005 Share Posted June 8, 2005 I had the factory head unit removed from my 2001 GS300 and replaced it with a Pioneer AVIC-N2. I'd like to hook the head unit up to the factory subwoofer amp. Is this possible? I don't know if the factory amp has RCA's or if there is something I can buy to convert the preouts to something the amp can use. Thanks for any help ← Does Unix have a search function? Try the search function of this forum to find your answer. Short answer: If you replaced your headunit and are using the factory speakers, you should already be using the factory amp and powering the sub. If your install included chopping up the OEM harness then it's going to be a little harder. There are various harnesses which you will find information about and sources for by searching these forums. Quote Link to comment Share on other sites More sharing options...
