Archie Posted May 18, 2005 Share Posted May 18, 2005 I had my LS400, 1990 with 80K miles checked by the dealer. It has a bad alternator. Car runs find for a week after charging then won't crank. After a fresh charge everything is fine. Had the battery and stuff checked at Sears (Diehard) and they said alternator is OK. Hmmm, Based on the recharging trick I tend to think it's the alternator. Dealer says $500 +. A post states that a leaky PS pump can spray the Alternator. I haven't checked for oil yet. The post also says pull the radiator to get to it. A very big job. Is this the only way to get to it? A rebuild shop locally says they will rebuild for $100 but they don't pull them. Any comments? Quote Link to comment Share on other sites More sharing options...
larryp Posted May 18, 2005 Share Posted May 18, 2005 Archie Replaced mine last year. You don't need to pull radiator - you can get it from underneath. I also replaced PS pump at same time cause it was leaking - probably causing premature failure of the alternator. I'd get a second opinion. Advance Auto Parts or Autozone should be able to check the battery and alternator on the car and tell you which one is bad. Advance diagnosed mine - i thought it was the battery but it was the alternator. It pretty much has to be one of the two based upon your description. Quote Link to comment Share on other sites More sharing options...
