Ac Recharge
jadecuir
A friend was recharging my AC system last night. He was not familiar with lexus, but has lots of AC background (navy, Nuc pwr plant, etc.) When he tried to pull a vacuum, He could only pull to -30 lbs, then it pulsated. Then we found the other low-side valve. I think we were pulling air in via that valve.
Car was previously diagnosed at an independent shop as having bad comp, but after partial charge and oil, we had 200 lbs on high side, 30 on low. Cold air again!
Question is, does anyone have the PDF section of the manual on hand? I'm away from my home computer, and I want to show my friend the specifics on the system: recharge procedures, capacities, etc.
Also, there were no caps on the three fittings. Shouldn't there be caps?
John D
Just an update: Yesterday I got some caps, and we vacuumed the system, after running it with oil/dye and r-22 half charge. With caps in place, it held vacuum! Charged with Honduran R-12, and we're cold again!
Watchin' for leaks,
John
