Code 25
Jungle
Intermit. check eng light over the past few weeks. Ran diagnostics today. Had code 25 (air/fuel mixture lean). Couldn't find anything here when I searched. Anyone ever had this? Bad O2 sensors? Thanks.
Jeff
Number of possibilities but the first probable cause listed in the diagnosis for this code is "open or short in main o2 sensor circuit" which probably means a bad main o2 sensor. Other possibilities are listed that include ignition system, fuel injector blockage, water temp sensor and so on.
