Diagnostic Code 45
Paul Sherman
Good Morning:
I have a '93 LS400 with 178K miles on it.
The 'trac' light was coming on sometimes (tires not slipping),
which implied a problem being logged. Sometimes, when it
happened while the engine was cold, the car would hesitate and
surge a little.
Using the info you all provided, I got the car into diagnostic mode
and it came up with
45 "When idle switch ON, main throttle position sensor signal
is 1.5V or higher"
What does that mean, and what do I do to fix it?
Again, this is one of the best support sites I've seen.
Thanks to all.
Might try cleaning the TPS sensor as your code indicates wrong voltage at idle. I don't know how you clean it, but someone has mentioned it. Also the TPS on your TRAC (if you have it) is apparently the same. Could try swapping the sensors. If this works, just buy a new TPS.
Good luck
Larry
