pastha40 Posted April 18, 2005 Posted April 18, 2005 Fuse is fine. So I'm assuming it must be switch/relay/ or wiring harness. Where can I find each of these and how can I tell if its the problem? Could it be anything else other than these three? Thanks in advance!
pastha40 Posted April 30, 2005 Author Posted April 30, 2005 SOLUTION: Stop light failure sensor had gone bad. Its located in the trunk under the lining on the left side quarter panel. Without this functioning properly the brake lights or tails or even both wont work. LExus dealer wanted $300 for part + 50 install. Bought online for 215 and installed myself. It just snaps into wiring harness.
bricksb Posted May 5, 2005 Posted May 5, 2005 SOLUTION:Stop light failure sensor had gone bad. Its located in the trunk under the lining on the left side quarter panel. Without this functioning properly the brake lights or tails or even both wont work. LExus dealer wanted $300 for part + 50 install. Bought online for 215 and installed myself. It just snaps into wiring harness. ← I have a 98 gs300 that the sensor has definitely gone bad. do you still remember who you bought yours from? Thanks.
pastha40 Posted May 5, 2005 Author Posted May 5, 2005 YES here is the link: http://www.trademotion.com/partlocator/ind...=213956&make=20
Stanley vanAsch Posted September 11, 2017 Posted September 11, 2017 I've got the same problem with mine, thanks for the help!!
