TunedRX300 Posted March 1, 2005 Share Posted March 1, 2005 My 2000 RX300 AWD's right license plate bulb burned out. Loosened the small philip screw but can't get the plastic cover off. Anyone has changed it? Is the bulb 168 or 2825? Thanks Quote Link to comment Share on other sites More sharing options...
ajvenuto Posted March 1, 2005 Share Posted March 1, 2005 Tuned, Your went in the right direction. You're almost there. After removing the phillips screw, lower the right side of the bulb housing. Then slowly and gently pull the housing by the lowered end, towards the right. The left side is held in place with a small tab that you will only see when the housing is completely removed. As far as the bulb, the owners manual only says it's a 5 watt type D bulb. Good Luck and Best Regards, Tony Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted March 1, 2005 Author Share Posted March 1, 2005 Tony Thanks, I got the plastic housing off and pried the bulb off the base with a flat head screw driver. Did you replace it with LED instead of incandescent? Quote Link to comment Share on other sites More sharing options...
ajvenuto Posted March 2, 2005 Share Posted March 2, 2005 Tuned, I'm glad you were able to get at the license plate bulb. To answer your question, I've not had to replace a license plate bulb on my RX300 yet. Regards, Tony Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted March 2, 2005 Author Share Posted March 2, 2005 Tony, Do you know RX300's front sidemarker has clear or amber bulbs? I want to move one of the bulbs (if it is clear ones) to license plate since I bought a pair of Euro clear sidemarkers with amber bulbs included. The bulbs are inter-changable, wedge ones according to Sylvania's web site. When they burn out again, it is LED time :P Quote Link to comment Share on other sites More sharing options...
ajvenuto Posted March 3, 2005 Share Posted March 3, 2005 Tuned, I'm guessing that the front sidemarker light bulbs are clear, but I don't know for sure. Quote Link to comment Share on other sites More sharing options...
ajvenuto Posted March 4, 2005 Share Posted March 4, 2005 Since you mentioned LED bulbs........ I'm new to the world of LED replacement bulbs. Can you fill me in on the advantages. I can think of one which is extended bulb life, but that's all I'm aware of. Thanks Quote Link to comment Share on other sites More sharing options...
TunedRX300 Posted March 4, 2005 Author Share Posted March 4, 2005 Update: Bulbs for front side markers are clear, but mine are rusted out. RX300's front sidemarkers are poorly protected from water, I have to replace bases also since rust killed all eletrical contacts. Luckily Euro clear sidemarkers I bought on Ebay came with two amber bulbs and two bases. Now I feel smart buying not just lens but complete assemblies. :P LED is solid state, which means no mechanical movable parts. A big plus since car movements shorten incandescent light's life. LED also does not generate heat and uses ~1/10 of power. Many people like LED because of color, e.g. hyper white LEDs do not have incandescent's yellowish color. A negative on LED its directional projection, or not spreading light to more than a single spot. Better designs shave the bulb head to spread light if it is single LED bulb. Others use multiple LEDs in one bulb, each w/ different projection angles. You also want >6 LEDs, better >9 LEDs in a bulb, if you want readable light. I will replace courtesy light with blue 9 LED bulb and use one of the clear ones for license plate. Blue is illegal in California for external usage. Quote Link to comment Share on other sites More sharing options...
