20 In Wheel Off Set
  • 2 years later...
good size will be 20x8.5 in the front and 20x10 in the back or 20x10.5
what off set can I use with my 20x10 rear my local discount tire recommended a 35 offset will I have to modify my rear fenders
Well I have 20x8.5 with 35mm offset on front and rear in my AWD and I have VERY minor rubbing only when reversing. U-turns and everything else is okay! I'm sure you can go 20x9 in the rear. It's the front control arm that cuts it close. I wouldnt recommend anything wider than 20x9 in front. Rear you should be okay.
