pachocco1 Posted January 12, 2005 Share Posted January 12, 2005 Does somebody have the key programming procedures from the 97 LS400 shop manual? I found a lot of loose instructions but I have had some problems. Also, I am trying confirm the that there is a difference in transponders between the 97's, 98-00's, & 01-05's. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
pachocco1 Posted January 13, 2005 Author Share Posted January 13, 2005 Here is what I found for the 97. Does anyone have anything different for the 97? -------------------------------------------------------------------------------------------------- Key blanks: Ilco / Silca TOY40BT4 Replacement key blanks can be ordered through any Lexus dealer. Programming replacement keys - 1997 LS400 only. 1. Enter the car and close all doors. Simultaneously depress and release both the brake and accelerator pedals. 2. Within 5 seconds, insert the working pre-programmed key into the ignition and cycle the ignition from the "off" position to the "on" position 5 times. Leave the ignition in the "on" position. 3. Within 15 seconds, open and close the driver’s side door one time. 4. Within 20 seconds, open and close the driver’s side door 5 more times. 5. Within 20 seconds, remove the working key from the ignition. 6. Within 10 seconds, insert the newly cut transponder key into the ignition, and turn the ignition to the "on" position. 7. Leave the new key in the ignition for at least 60 seconds. 8. After 60 seconds the programming should be complete. 9. If you are programming additional keys, insert the next key within 10 seconds of removing the last, and turn the ignition to the "on" position. Once again, leave the key in the “on” position for at least 60 seconds. 10. Start the vehicle to verify that programming has been successful. Quote Link to comment Share on other sites More sharing options...
