Hi all...need helps... i have a 95 sc300 with several problems...
airbag light and TRAC light are on all the time.... asked the Lexus dealer, he said that airbag and TRACTION control might not work at all... is that true? it would cost me $150 just for them to check these problems and more if I want to fix them... Is there any else i could do?
thanks all
PM me and I can email you the basic diagnostic procedure. If you can splice two wires, connect two to three prongs in the in cab diag unit and count how many times the MIL blinks, then you can pull the code yourself.
