cbeeson71 Posted December 26, 2004 Share Posted December 26, 2004 I recently purchased a 1996 LS 400 with 78K miles. After I drove the car a while, I started noticing that whenever I press the brakes the car shifts to the right, just slightly, and then right back whenever the brakes are unpressed. This is just a slight shift or wiggle, but I've never noticed it in any other car. I was just wondering if anyone has had this situation occur and what suggestions you may have? I was also wondering if it had anythng to do with the ABS, since this is the first car that I've owned with ABS? Also, I just recently had all rotors turned and new pad installed on all four corners, but this did not stop the shifting. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted December 26, 2004 Share Posted December 26, 2004 Possibly the air pressure in your tires is not even? Quote Link to comment Share on other sites More sharing options...
95LS400Bob Posted December 26, 2004 Share Posted December 26, 2004 Or loose suspension component on the right side. As in strut bar bushing. Quote Link to comment Share on other sites More sharing options...
