martind43 Posted December 20, 2004 Share Posted December 20, 2004 I live a distance from my Lexus dealer so I do my own oil chages on my 2004 LS430 every 5,000 miles as prescribed. How is the service reminder light reset? Thanks Quote Link to comment Share on other sites More sharing options...
Unlisted Posted December 20, 2004 Share Posted December 20, 2004 I live a distance from my Lexus dealer so I do my own oil chages on my 2004 LS430 every 5,000 miles as prescribed. How is the service reminder light reset?Thanks ← put the key in the off position , hit the trip/odemeter button until it reads odometer then hold in, turn car on and you should see /// in the odometer . let go and your done Quote Link to comment Share on other sites More sharing options...
stuartr Posted January 13, 2005 Share Posted January 13, 2005 I live a distance from my Lexus dealer so I do my own oil chages on my 2004 LS430 every 5,000 miles as prescribed. How is the service reminder light reset?Thanks ← put the key in the off position , hit the trip/odemeter button until it reads odometer then hold in, turn car on and you should see /// in the odometer . let go and your done ← Note that you have to set the trip/odometer to the "BLANK" display. Be sure you only turn the Ignition switch back to "ON" and not "START". If you restart the car, the service reminder light will NOT reset! Quote Link to comment Share on other sites More sharing options...
cgazsc Posted January 18, 2005 Share Posted January 18, 2005 I live a distance from my Lexus dealer so I do my own oil chages on my 2004 LS430 every 5,000 miles as prescribed. How is the service reminder light reset?Thanks ← put the key in the off position , hit the trip/odemeter button until it reads odometer then hold in, turn car on and you should see /// in the odometer . let go and your done ← Note that you have to set the trip/odometer to the "BLANK" display. Be sure you only turn the Ignition switch back to "ON" and not "START". If you restart the car, the service reminder light will NOT reset! ← This doesn't work for me(2004 LS430 w/NAV). If I turn off ignition, I can't see odometer. So do I push while in ON position, then OFF and back ON(all while holding TRIP) or some other magic combo? Quote Link to comment Share on other sites More sharing options...
stuartr Posted January 26, 2005 Share Posted January 26, 2005 I live a distance from my Lexus dealer so I do my own oil chages on my 2004 LS430 every 5,000 miles as prescribed. How is the service reminder light reset?Thanks ← put the key in the off position , hit the trip/odemeter button until it reads odometer then hold in, turn car on and you should see /// in the odometer . let go and your done ← Note that you have to set the trip/odometer to the "BLANK" display. Be sure you only turn the Ignition switch back to "ON" and not "START". If you restart the car, the service reminder light will NOT reset! ← This doesn't work for me(2004 LS430 w/NAV). If I turn off ignition, I can't see odometer. So do I push while in ON position, then OFF and back ON(all while holding TRIP) or some other magic combo? ← With the ignition ON, change the odometer display to the BLANK setting. Now hold down the odometer reset button and switch the ignition switch to OFF and back to ON (Not START). This should reset the service reminder. Quote Link to comment Share on other sites More sharing options...
