Vette Boy Posted December 17, 2004 Share Posted December 17, 2004 When I really step on my brakes the front end shimmys just a little bit, I can feel it through the steering wheel. Is it rotors, bushings or something else? Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted December 17, 2004 Share Posted December 17, 2004 When I really step on my brakes the front end shimmys just a little bit, I can feel it through the steering wheel. Is it rotors, bushings or something else? ← You could try a shock tower brace to stiffen it up some. Maybe shocks and springs as well and change the swaybar bushings. :whistles: Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted December 17, 2004 Share Posted December 17, 2004 Or, you could try the rotors. This has been the case in 99% of the cars I work on..all shapes and kinds. Having the rotors machined (cut) should verify you found the problem. After you have it done, don't be surprised if the problem returns fairly rapidly. This often happens after rotors have been machined. The only sure cure then is to replace them. Quote Link to comment Share on other sites More sharing options...
Vette Boy Posted December 17, 2004 Author Share Posted December 17, 2004 You could try a shock tower brace to stiffen it up some. Maybe shocks and springs as well and change the swaybar bushings.:whistles: ← So you're saying the shimmy is normal and I need to upgrade the shocks/springs and swaybar bushings to make it right? Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted December 17, 2004 Share Posted December 17, 2004 Not sure if we're thinking of the same thing in regards to sway. I'm thinking of sway in the front if so then thats a way to stiffen it up. I would try the rotors first, maybe get some new drilled/slotted ones, guy is pretty knowledge if he says rotors. I'd go with his recommendation first. Then, if the problem is still there try the shock brace and sway bar bushings or even a stiffer bar B) Quote Link to comment Share on other sites More sharing options...
Vette Boy Posted December 17, 2004 Author Share Posted December 17, 2004 ...The only sure cure then is to replace them. ← What's a good brand? I see rotors on-line for ~$120 a set. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted December 17, 2004 Share Posted December 17, 2004 ...The only sure cure then is to replace them. ← What's a good brand? I see rotors on-line for ~$120 a set. ← Brembo, something that has a plated hub for rust protection. I bought a set off EBay for $139 for all 4, they look fine to me. Quote Link to comment Share on other sites More sharing options...
