Cigratte Lighter Fuse
forswami
Hi, It's fuse # 5, 15 Amp rating, located at the driver's side kick panel. If you exit your car and lean your head under the dash on the left of the steering wheel and look up, you'll see a little panel. Remove the cover and you'll see a fuse box. Thats driver's side kick panel. Hope this helps.
If the fuse is good and there is still no power it is possible that you burned through a fusable link which is located on the back of the lighter receptacle. If you take an ohm meter you should be able to isolate it. I soldered a small wire across the link which is still backed up by the fuse and saved probably $150 at the dealer.
Good luck
