Brakes Sticking?
For about a week now I have noticed my brakes(rear from the sounds of it) make a grinding noise while I'm backing out of my driveway. Same sound is heard when I almost come to t a complete stop. Now the sound is there while driving, a SHH SHH SHH sound like they pads are slightly touching the rotor. What could be the cause of this?
I checked the pads and they all seem OK so it isnt the wear indicator rubbing. Any suggestions or other items I should check out would greatly help. Thanks.
Sorry its a 95 GS300, is the ebrake on these cars hydraulic or just a cable...how would i go about adjusting it if it is not disengaging all the way.
I don't see how I have warped rotors when I had no problems before, this issue first came after a heavy rain, since then I've been hearing noise.
Hot brakes, heavy rain, could definitely be warped. Jack it up and spin the tires and see what you can find out. :whistles:
