landolakes Posted November 17, 2004 Share Posted November 17, 2004 For about a week now I have noticed my brakes(rear from the sounds of it) make a grinding noise while I'm backing out of my driveway. Same sound is heard when I almost come to t a complete stop. Now the sound is there while driving, a SHH SHH SHH sound like they pads are slightly touching the rotor. What could be the cause of this? I checked the pads and they all seem OK so it isnt the wear indicator rubbing. Any suggestions or other items I should check out would greatly help. Thanks. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted November 17, 2004 Share Posted November 17, 2004 ckeck for warped rotors, emergency brake cable play :P Put the rear of the car up ona jack and spin the tires and see if you can replicate the noise. Also, you need to put year of your car in posts. Quote Link to comment Share on other sites More sharing options...
landolakes Posted November 17, 2004 Author Share Posted November 17, 2004 Sorry its a 95 GS300, is the ebrake on these cars hydraulic or just a cable...how would i go about adjusting it if it is not disengaging all the way. I don't see how I have warped rotors when I had no problems before, this issue first came after a heavy rain, since then I've been hearing noise. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted November 18, 2004 Share Posted November 18, 2004 Sorry its a 95 GS300, is the ebrake on these cars hydraulic or just a cable...how would i go about adjusting it if it is not disengaging all the way. I don't see how I have warped rotors when I had no problems before, this issue first came after a heavy rain, since then I've been hearing noise. ← Hot brakes, heavy rain, could definitely be warped. Jack it up and spin the tires and see what you can find out. :whistles: Quote Link to comment Share on other sites More sharing options...
newport Posted November 18, 2004 Share Posted November 18, 2004 I had the same thing on my mk1, it was worn out parking brake shoes metal to metal on the inside of the drum. Lexus fixed it! new shoes new disks/drums and pads both sides cost loads :cries: Quote Link to comment Share on other sites More sharing options...
