I have a professionally modified IS-300 (58k miles) in excellent condition.  Was very active in shows and groups but then my professional life started and I don't have the time to devote that I used to have ... it a sad day but I was hoping for some advice on best resources/options to trade or sell ... all thoughts welcome.
Was built by Sound Performance (IL) and featured in Modified Magazine (March 2008)
ENGINE • Engine 2JZGE-T 3.0-liter DOHC Turbocharged I-6
NUMBERS • 301 RWHP; 326 RWTQ @ 7psi (Mustang Dyno)
ENGINE MODIFICATIONS • Precision PT5858 Dual Ball Bearing Water-Cooled CEA Turbo Charger w/Heat Wrap • SPL Iron Cast Manifold w/Heat Wrap • Tial 38-mm Wastegate • Turbo XS Type-H Blow-Off Valve • RC Engineered 440-cc Injectors • Walbro 255-iph Fuel Pump • Precision Front Mount Intercooler • 3” Downpipe • 3” SRT Exhaust • 3” Dynomax VT Muffler  • NGK Iridium IX Spark Plugs • Stainless Steel Oil Supply & Return Lines • Greddy EVO II Cat-Black  exhaust • Greddy Polished Oil Catch Can • AMS Full Synthetic Oil • Pro Lex Performance Aluminum Radiator Cooling Panel • Teck Grounding Kit
ENGINE MANAGEMENT • AEM EMS Full Standalone – 3 Bar MAP Sensor
DRIVETRAIN MODIFICATIONS • Swift Racing Technologies Valve-Body • Transmission Upgrade • Transmission Cooler
WHEELS / TIRES / SUSPENSION / BRAKES • Diamond-Cut Forged Aluminum / Aodhan AH02 18x8.5 +35mm 5x4.5 • Vercelli Strada II / 225/40ZR18 92W XL • HKS Hipermax II 30-Way Adjustable Coilovers • Hotchkis Front & Rear Sway Bars • CuscoaJDM Altezza Rear Trunk Brace • Pro Lex Performance (PLP) Front & Rear Strut Braces • Tunedparts Rigid Under Braces • 4-Point Harness Bar • Stop Tech Stainless Steel Brake Lines • Stop Tech Slotted Rotors • Axxis Ultimate Ceramic Pads • Motul Performance Brake Fluid
EXTERIOR • VIS Carbon Fiber Front Lip – cracked • Carson Tuned JDM Real Lip Valence • L-Tuned Side Skirts • TRD Carbon Fiber Grille • Graphite Grey Pearl Color Matched Headlights • Flat Black Fog Lights • Flat Black Smoked Side  markers • OEM Lexus Black Pearl Emblems • Custom Black Pearl Rear “T” Emblem • 30% Graphite Tint • Disabled Daytime Running Lamps • Standalone Fog Light Modification • Acura RDX Turbo Emblem (front grille) • JDM Altezza Short Antenna • Custom Painted Pin Stripe
INTERIOR • Sparco Torino Chairs - Driver & Passenger • Sparco Floor Mats • Defi 52-mm Mechanical Boost Gauge • Defi 52-mm Exhaust Gas Temperature Gauge • AEM UEGO 52-mm Wideband • JDM Altezza Non-Smokers Box • Lexus OEM Navigation
Thanks
