Jeffrey Draxten Posted September 4 Share Posted September 4 (edited) PROFESSIONALLY MODIFIED - MAGAZINE FEATURED 2002 GGP Lexus IS300 TURBO w/ AEM EMS - 301 RWHP ; 326 RWTQ @ 7psi (Mustang Dyno) – Modified Mag Full Feature (March 2008 Issue) Car is in excellent condition, has been extremely well taken care of and has only 58k miles (normal wear & tear – few scratches/scraps) Upgrades/Build performed by Sound Performance in IL (nationally known) Featured in Modified Magazine March of 2008 with a full spread and write-up well over $25k in modifications not including labor and wheels/tires ENGINE • Engine 2JZGE-T 3.0-liter DOHC Turbocharged I-6 NUMBERS • 301 RWHP; 326 RWTQ @ 7psi (Mustang Dyno) ENGINE MODIFICATIONS • Precision PT5858 Dual Ball Bearing Water-Cooled CEA Turbo Charger w/Heat Wrap • SPL Iron Cast Manifold w/Heat Wrap • Tial 38-mm Wastegate • Turbo XS Type-H Blow-Off Valve • RC Engineered 440-cc Injectors • Walbro 255-iph Fuel Pump • Precision Front Mount Intercooler • 3” Downpipe • 3” SRT Exhaust • 3” Dynomax VT Muffler • NGK Iridium IX Spark Plugs • Stainless Steel Oil Supply & Return Lines • Greddy EVO II Cat-Black Exhaust • Greddy Polished Oil Catch Can • AMS Full Synthetic Oil • Pro Lex Performance Aluminum Radiator Cooling Panel • Teck Grounding Kit ENGINE MANAGEMENT • AEM EMS Full Standalone – 3 Bar MAP Sensor DRIVETRAIN MODIFICATIONS • Swift Racing Technologies Valve-Body • Transmission Upgrade • Transmission Cooler WHEELS / TIRES / SUSPENSION / BRAKES • Diamond-Cut Forged Aluminum / Aodhan AH02 18x8.5 +35mm 5x4.5 • Vercelli Strada II / 225/40ZR18 92W XL • HKS Hipermax II 30-Way Adjustable Coilovers • Hotchkis Front & Rear Sway Bars • CuscoaJDM Altezza Rear Trunk Brace • Pro Lex Performance (PLP) Front & Rear Strut Braces • Tunedparts Rigid Under Braces • 4-Point Harness Bar • Stop Tech Stainless Steel Brake Lines • Stop Tech Slotted Rotors • Axxis Ultimate Ceramic Pads • Motul Performance Brake Fluid EXTERIOR • VIS Carbon Fiber Front Lip – cracked • Carson Tuned JDM Real Lip Valence • L-Tuned Side Skirts • TRD Carbon Fiber Grille • Graphite Grey Pearl Color Matched Headlights • Flat Black Fog Lights • Flat Black Smoked Side Markers • OEM Lexus Black Pearl Emblems • Custom Black Pearl Rear “T” Emblem • 30% Graphite Tint • Disabled Daytime Running Lamps • Standalone Fog Light Modification • Acura RDX Turbo Emblem (front grille) • JDM Altezza Short Antenna • Custom Painted Pin Stripe INTERIOR • Sparco Torino Chairs - Driver & Passenger • Sparco Floor Mats • Defi 52-mm Mechanical Boost Gauge • Defi 52-mm Exhaust Gas Temperature Gauge • AEM UEGO 52-mm Wideband • JDM Altezza Non-Smokers Box • Lexus OEM Navigation MAINTENANCE • Oil changes done every 1,500 miles • New NGK Iridium Spark Plugs • Maintenance Current • Have had a few fuse issues with add-on gauges Edited September 4 by Jeffrey Draxten update Quote Link to comment Share on other sites More sharing options...
