Fi7e Posted March 23 Share Posted March 23 Trust me, I’ve searched and watched almost every YouTube video I can find. my car is a imported 1997(1998) Celsior with only 42,000 miles and bone stock. Runs/drives great. here’s the full list of what’s not working horn, door dome light, power folding mirrors/mirror adjusters(mirror vibrator works), remote key, saved seat/steering wheel memories, master window switch/lock(drivers window works)[all window switches work at each door], don’t think my bumper cornering blinker lights turn on with blinkers(bulbs are good), drivers side seat belt height switch, and I think I found out today my cruise control doesn’t work. Checked EVERY fuse in engine bay and kick panel, all good and clean. Dome light turns on manually but won’t with doors. Every light works except possibly my cornering lights. All other systems work perfectly. Touch screen is fine, radio works, function buttons on steering wheel works, all electric seat buttons work, steering wheels telescope/height, etc. no dash codes or check lights on. many people have one or two of these issues independently but not all together, and their fixes are usually fuses or high mileage wear and tear. The key remote has newer batter and will beep but not unlock the doors. i have unplugged the battery a number of times but none of the typical system resets seem to work in my situation. I have a hard time believing all these systems are connected to one problem but my friend i got the car from drove it from the port in Cali all the way up the coast to WA and said EVERYTHING worked perfectly before it sat for a number of months. Quote Link to comment Share on other sites More sharing options...
Fi7e Posted March 26 Author Share Posted March 26 Let me refine and simplify my issue. Anything not listed below works fine. -Key remote will pop trunk. It only beeps if I push the Lock button but not Unlock. Won’t unlock/lock doors. -Power locks don’t work with or without key remote. Locks only work manually. -Window switch only works after I lock/unlock the door, then works fine. Master switch only controls drivers window -Horn doesn’t work - fuse is good and I can hear the horn relay clicking when horn is pressed, so that rules out bad switch or clockspring. -Dome light doesn’t work on “door” setting, but works when switched to “on” position. -Drivers side seatbelt height adjuster doesn’t work, passenger side does -Side mirror adjuster doesn’t adjust either mirror -Power folding mirrors don’t work, mirror vibrator works -Seat/steering wheel memories won’t program or work - all seat and steering wheel adjusters do work. All fuses are good. Haven’t checked every relay though. No CEL or Airbag lights. Quote Link to comment Share on other sites More sharing options...
Fi7e Posted April 7 Author Share Posted April 7 Problem solved. Bad battery. It checked out as good, was running at 12v and the car was running at 14.5v but replaced the battery with an Optima red top and everything works perfectly. horn doesn’t work because someone removed the actual horns in Japan for some reason. Quote Link to comment Share on other sites More sharing options...
