steventodd Posted November 8, 2004 Posted November 8, 2004 hello everyone, just got my lexus this weekend. i was looking to install my subwoofers. i have everything wired up but i dont have the subwoofers wire up to the factory harness. if anybody knows the color codes are for the rear speakers please help.
lordzatez Posted January 8, 2005 Posted January 8, 2005 As per the Lexus 01 electrical manual it shows as follows in the picture---- on the left hand side the LH rear speaker goes from SP+ on the transceiver/speaker relay to speaker and the color is black the other lh rear speaker wire goes from SP- on the transceiver/speaker relay to the other side of thr rear lh speaker and the color is yellow-----The lh rear subwoofer goes as follows from WFL+ on the amplifier to the lh sub and its B-W black-white and the other wire goes from WFL- on the amp to the lh side sub and is Y-R yellow-red wire.----On the RH rear speaker wire goes from RR+ on the amp to the RH rea speaker and is RED in color the other RH rear speaker wire comes from RR- on the amp to the rh rear speaker and is WHITE in color THe RH sub goes from the WFR+ om the amp to the rh rear sub and is R-W red-white the other sub wire goes from WFR- on the amp to the other side of the sub and is W-L white-blue stripe -------- I hope that helps more than confuses I took it right out of the factory book if you have and questions let me know or I can e-mail you picts of the diagraghm in the book. Lexus Ninja Guy
