kaizen Posted January 22 Share Posted January 22 I need help my steering wheel did 360 rotation after hearing a snapping noise , I took my column apart and seen the gears that connect from the shaft the the wheel had broke witch gave my wheel a lot of free play n also wouldn’t steer my wheels , could someone tell me if I can replace the gear or if I have to replace the whole column and if I do have to replace the whole column where could I possibly find one for a 92/93 ls400 with memory tilt I’m struggling to find anything so any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
DirtyWetRag Posted August 20 Share Posted August 20 Did you ever figure anything out? I have a problem where the telescopic motor plugs in. I'm finding it hard to figure out what if any other models carry the same column for a swap incase the rear receiver is trashed. (The worm drive has a decent amount of rust at the tip) Quote Link to comment Share on other sites More sharing options...
