Shimshady Posted December 26, 2023 Share Posted December 26, 2023 So I have this 92’ Es 300 that I’ve been using as my daily for awhile and recently it’s been having some electrical issues. A weeks ago the battery light came on, when I popped the hood to see if anything was wrong the wire on the top side of the alternator was completely burned off. After some time I eventually got the wires back into place but it hasn’t been a permanent fix and the wired have burned off to some extent a few more times. I have noticed that if I reduce the amount of electrical load in the car it’s usually fine. Now that I have time to work on it what should I be looking at first? Is this an alternator issue or a grounding issue? Or is it something either issue I’m not seeing Quote Link to comment Share on other sites More sharing options...
thomas garcia Posted June 20 Share Posted June 20 I have similar problem. I replaced the radiator electric fan because one the fan motors (passenger side) melteed the plastic shroud and left the fan motor hanging.i replace the electric fan and alternator started makong a noise the died. I replaced the alternaor but when i reconnected the battery it blew out alternator120 amp fuse. I replaced the fuse and reconnected the battery, positive first and then i connected the the negative, the terminal melted part of the negative post and blew the alternator 120 amp fuse again. My question is it a bad ground and if so where? Could it be that a bad ground or short caused the electric fan motor to burn through plastic shroud? How do i find the bad ground or short if i can't connect the battery? Quote Link to comment Share on other sites More sharing options...
