timmm Posted August 26, 2023 Share Posted August 26, 2023 The electrical system on my 2005 ES330, 220,000 miles, has stopped operating. When I try to start it, nothing but "check engine" light comes on. Everything else is completely dark. Remote starter starts the engine, but then I have to shift into gear using the override button. Any ideas what's wrong? Quote Link to comment Share on other sites More sharing options...
Volleypop Posted August 26, 2023 Share Posted August 26, 2023 I find it interesting that the car starts with the remote which indicates the engine and that portion of the system is OK. Does anything else work when it's running ? Perhaps the remote starter is causing the issue. There should be a manual override switch to disable it. I would try shutting it off and then starting the car normally. Also maybe something as crazy and simple as changing the battery in your remote FOB ? Otherwise might be something in the ignition switch or steering column like loose connector ? All I have to offer offhand ....not a mechanic 😞 Quote Link to comment Share on other sites More sharing options...
