1990 Ls400 Weird Starting Issue!
thewzdoc
Hi All,
My Lexus has decided that it doesn’t want to start when I want it to start… Normally it is in the morning I go out and turn the key and nothing…if I leave the ignition on for a few minutes I will hear a “CLICK” from under the hood (sounds like the passenger side) and then it will start.
I tried using jumper cables but the same thing happens. After it is running the charging system is working and the battery shows ~14 volts.
After it has been running for a while and it is warm it will start with no problem…
Is there a starter relay somewhere that could be on its way out? If so where is it and what is it called?
Thanks in advance for the help!
