parking light replacement
RB48
The passenger side front parking light is burned out.  Videos show removal of the entire headlight assembly but I was wondering if the parking light bulb alone can be replaced through the wheel well without the laborious removal of the entire headlight unit?
On my rx300 I can change mine out pretty quickly up front without removing the tire or to much trouble in the back the tire has to come off
If it says the front end comes off it is required.  I had a fog light out. Entire front end off to change the bulb. Needless to say Every single light in the front end was changed at the same time.
