sizzler25 Posted October 29, 2004 Share Posted October 29, 2004 Hey all, Sorry to beat a dead horse. I've looked through old posts and still have a couple questions about getting a new remote key. Obviously the better way (cheaper) to go is buy one through ebay or a dealer that sells them cheap then program yourself and have it cut. In reading the posts, there are references to a Master key and Sub key. I only got one key from the place I bought my 99gs3 from. Posts say I need a Master key in order to program a new key. So my question is how do i know if i have a master key? TIA, Sizzler Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted October 29, 2004 Share Posted October 29, 2004 If the car starts, you've got the master key! :P Quote Link to comment Share on other sites More sharing options...
THE ONE Posted October 30, 2004 Share Posted October 30, 2004 Hey all,Sorry to beat a dead horse. I've looked through old posts and still have a couple questions about getting a new remote key. Obviously the better way (cheaper) to go is buy one through ebay or a dealer that sells them cheap then program yourself and have it cut. In reading the posts, there are references to a Master key and Sub key. I only got one key from the place I bought my 99gs3 from. Posts say I need a Master key in order to program a new key. So my question is how do i know if i have a master key? TIA, Sizzler ← THE BIG FAT KEY WITH THE 3 BUTTONS ( DOOR AND TRUNK AND PANIC ) IS THE MASTER KEY. GOOD LUCK MY FRIEND. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted October 30, 2004 Share Posted October 30, 2004 If the car starts, you've got the master key! :P ← Not necessarily true. A valet key (no remote) will also start the car. To make matters even worse, a valet key can be programmed as a master as well. This is a useful note when getting additional keys made because you can get a valet key, program it as a master, and then you could get additional keys (remote or valet) made from it. To be technically correct, to make any additional key you need: 1. Any key that has been registered to the car as a master. 2. Any blank, remote-master or valet cut to the cars key code (obtainable from the VIN). 2. If no keys are available, an original master (and/or valet) can be originated using the cars key code and by replacing the ECM (normally done once by a dealer, free of charge as a courtesy). If you have to pay out of pocket, hold on, it's not cheap. Quote Link to comment Share on other sites More sharing options...
ColinBarber Posted November 2, 2004 Share Posted November 2, 2004 2001+ models can have a master key programmed by Lexus dealers without having an already programmed master key or swapping out the ECU. Pre 2001 models it's as GuyTelefunken said, very expensive. Quote Link to comment Share on other sites More sharing options...
