LuvmyLexus Posted October 28, 2004 Share Posted October 28, 2004 I have a 96 LS400. If I'm cruising anywhere from 40 to 60 mph and I let off the gas, the RPM drops around 1000 RPMs. It happens when I'm trying to maintain a constant speed and I am feathering the gas. There is a jerking motion as i go back on the gas. Any ideas?...Throttle control? transmission control? Thanks Quote Link to comment Share on other sites More sharing options...
jsurface Posted November 14, 2004 Share Posted November 14, 2004 I have a 96 LS400. If I'm cruising anywhere from 40 to 60 mph and I let off the gas, the RPM drops around 1000 RPMs. It happens when I'm trying to maintain a constant speed and I am feathering the gas. There is a jerking motion as i go back on the gas. Any ideas?...Throttle control? transmission control? Thanks ← I have the same exact problem with my 96. Did you ever find out what is causing the problem? Please email me at surf@carolia.net Thanks, J Surface Quote Link to comment Share on other sites More sharing options...
jsurface Posted November 14, 2004 Share Posted November 14, 2004 I have a 96 LS400. If I'm cruising anywhere from 40 to 60 mph and I let off the gas, the RPM drops around 1000 RPMs. It happens when I'm trying to maintain a constant speed and I am feathering the gas. There is a jerking motion as i go back on the gas. Any ideas?...Throttle control? transmission control? Thanks ← I have the same exact problem with my 96. Did you ever find out what is causing the problem? CORRECT EMAIL Please email me at surf@carolina.net Thanks, J Surface ← Quote Link to comment Share on other sites More sharing options...
VMF Posted November 15, 2004 Share Posted November 15, 2004 there was a recall regarding the ECM for the genII LS, call your dealer with the problem and have ur VIN number ready. your car might qualify for the recall. Quote Link to comment Share on other sites More sharing options...
