mikecib Posted October 25, 2004 Share Posted October 25, 2004 can anyone tell me how to remove the plexiglass covering the instrument panel? i need to clean the backside which has waterstains on it. Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted October 25, 2004 Share Posted October 25, 2004 Hello and welcome to LOC. Waterspots on the inside of the cluster cover? Strange. Any idea how that happened? I am guessing you will have to remove the housing around the cluster. Not sure about the 99s. Quote Link to comment Share on other sites More sharing options...
99lsguy Posted October 26, 2004 Share Posted October 26, 2004 can anyone tell me how to remove the plexiglass covering the instrument panel? i need to clean the backside which has waterstains on it. ← I know how to remove the plastice base of it.........the one piece that has a hole in the left side where the "interior dimming switch" is....... Take coat hanger wire or similar and make a 8" long piece with a little 1/2" hook at the end (90 degree). This should slip between the plexi and this top cover. Hook it and gently pull on each side and this top piece above the steering column will slide out. Then you could see if this plexi shield will just slide down and out or whatever... Quote Link to comment Share on other sites More sharing options...
mikecib Posted October 26, 2004 Author Share Posted October 26, 2004 can anyone tell me how to remove the plexiglass covering the instrument panel? i need to clean the backside which has waterstains on it. ← I know how to remove the plastice base of it.........the one piece that has a hole in the left side where the "interior dimming switch" is....... Take coat hanger wire or similar and make a 8" long piece with a little 1/2" hook at the end (90 degree). This should slip between the plexi and this top cover. Hook it and gently pull on each side and this top piece above the steering column will slide out. Then you could see if this plexi shield will just slide down and out or whatever... ← [/quote Quote Link to comment Share on other sites More sharing options...
mikecib Posted October 26, 2004 Author Share Posted October 26, 2004 thanks i'll try it. Quote Link to comment Share on other sites More sharing options...
