Removing Tail Light Assembly 94' Ls
gbls
Can someone explain how to remove the tail light assenbly on the 94' LS? The earlier posts I've read don't give actual info on how to do it. I have a brake light out and I was told that the lights in the main square tend to go black periodically. Help!
This should help you: http://www.lexls.com/tintedtaillights.html
For the inner lights on the trunk lid...you don't need to remove the grey trim panel at all. There are two velcro flaps that allow you to access the back of the bulb housing (grey piece with two silver colored screws in step 3). Flip those open then unscrew the two screws that hold the grey plastic housing on. Pull the housing out, it contains the bulbs.
