raspberrysoda Posted October 3, 2004 Share Posted October 3, 2004 I just acquired a '92 SC 400. At first I could open the passenger door from the inside, but now it won't open at all! The window is off track so I'm not sure if that has something to do with the problem. Any advice? Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted October 3, 2004 Share Posted October 3, 2004 Pull the door panel off and check the door handle mechanism. My pass. side won't open from the outside. There is a little plastic clip that holds lock rod in outside handle and it's broken. There is a similar arrangement from the inside handle Quote Link to comment Share on other sites More sharing options...
raspberrysoda Posted October 4, 2004 Author Share Posted October 4, 2004 Pull the door panel off and check the door handle mechanism. My pass. side won't open from the outside. There is a little plastic clip that holds lock rod in outside handle and it's broken. There is a similar arrangement from the inside handle ← Thanks!!! I'll check it out tomorrow. Quote Link to comment Share on other sites More sharing options...
